enable ospf export vr
enable ospf export {vr} vr-name route-type [policy-map | cost cost type ase-type-1 | ase-type-2] {tag number}] {exclude-private}
Description
Enables redistribution of routes between OSPF instances.
Syntax Description
vr Specifies Virtual Router.
vr-name Specifies the source Virtual Router for exported routes.
route-type Specifies the OSPF inter-VR export route type.
policy-map Specifies the route map.
cost Specifies cost.
cost Specifies the cost metric. Range is 0-65535.
type Specifies route type.
ase-type-1 Specifies AS-external type 1 routes.
ase-type-2 Specifies AS-external type 2 routes.
tag Specifies a tag.
number Specifies a tag value.
exclude-private Specifies to exclude routes corresponding to private IP ranges. Default is include private.
Default
N/A
Usage Guidelines
This command is executed in the destination VR and specifies the source VR.
The exclude-private option excludes prefixes in the private IP address ranges. Only OSPF route types can be exported between instances.
The following command enables OSPF ??:
enable ospf export vr cost 1 ase-type-1 tag 0
This command was first available in ExtremeXOS 32.3.
Platform Availability
